Thread Tools Rating: Thread Rating: 17 votes, 4.76 average. Display Modes
Knez
Knez's Avatar
10.17.2011, 06:34 PM
I would like to see at least 4mm shaft on shocks...
Flux 5B CC 1520
1/16 Rally
My Youtube
Russian:Life and Trust is Lost Only Once!
Knez
Knez's Avatar
10.17.2011, 07:11 PM
Wow, ver ynice build.
Will you have any spear XL aarms for sale ?
Nice bumpers, you could make more of them
If they hold i would be interesting...
Also where did you order custom dogbones ?
Very interested in mid. diff conversion.
Do you know the size of xxl shocks from eye to eye ?
Flux 5B CC 1520
1/16 Rally
My Youtube
Douwe
10.18.2011, 01:31 AM
The shaft size for these Losi XXL shocks could be 4mm (if they are the same as the LST2 shocks) : http://scriptasylum.com/rc_speed/shocks.html but I will measure them when they arrive.
pietrvds
10.20.2011, 12:12 PM
allright! those are shocks Douwe ;)
Knez
Knez's Avatar
10.20.2011, 12:35 PM
Thanks for the pic., whats the weight of the shocks and what W oil you will use?
So, they are around 5mm shorter than stock flux from eye to eye..
Flux 5B CC 1520
1/16 Rally
My Youtube
Douwe
10.20.2011, 12:57 PM
Don't trust the picture (because if the lens distortion), I measured the shocks and the XXL shocks are about 10 mm shorter than the stock flux shocks.
Just to be sure, the shocks are (from top to bottom):
- savage nitro shocks
- losi XXL shocks (obvious )
- savage flux shocks
brian015
brian015's Avatar
10.20.2011, 01:50 PM
For my large buggy (19lbs.) I've used the LST shocks with a lexan piece on the shock piston:
http://www.rc-monster.com/forum/show...&postcount=119
I've used 20-30wt oil with this setup with good results. The lexan piece helps damping as the shock compresses, but allows quicker rebound (due to the relatively light-weight oil). I also use RCRaven springs - they are the best for the LST shocks.
-brian
Douwe
10.20.2011, 02:26 PM
The weight of a single shock is 90 grams.
I will have to do some more research on which oil thickness and also which springs I will use.
_dV
10.21.2011, 02:00 AM
I've also used these shocks with the Raven dual rate springs. Very smooth but even though the shaft is 4mm it's not as strong as the stock Flux shock. I bent plenty of those shafts before going back to stock shocks. The other problem is that the plastic caps tend to rip off under pressure, metal caps might help.
Knez
Knez's Avatar
10.21.2011, 09:56 AM
Thanks for infos..
I ordered GD front shocks :) : http://rc-car-online-shop.de/shop/en...nt-2-pcs-.html
Flux 5B CC 1520
1/16 Rally
My Youtube
Knez
Knez's Avatar
10.28.2011, 06:12 AM
One Savage flux A720 = 59g
One GD shock = 129g
These are masive !
also received Xerun 150A esc...this was faaast.
Flux 5B CC 1520
1/16 Rally
My Youtube
Douwe
10.28.2011, 08:18 AM
One GD shock = 129g
These are masive !
Wow, these are indeed big!
I also received my Xerun 150 but I am now waiting for the 6.5 mm Castle plugs to connect it to my Castle motors
pietrvds
10.28.2011, 06:01 PM
what's the diameter of those shafts??? my losi's are 4mm and for theire size a bit to thin imho. These shocks you have are pretty cheap and look mighty beefy so letme know plzzzzzzzzzzzzzz ;)
Knez
Knez's Avatar
10.28.2011, 09:02 PM
Well i am thinking to go 6mm all over the truck this time, as i got xerun, mxl and few motors but not enough 6,5mm connectors :)
Pietrvds - Here infos
Dimensions:
Mounting hole distance (extended): 152 mm
Total length (extended): 170 mm
Travel: 42 mm
Shock shaft diameter: 6 mm
Body diameter: 30 mm
Upper shock hole is M8, i will use 8mm diameter sleve woith inner hole M4...
Hope Alza dosent have too much work these days and this gets cut fast :)
Flux 5B CC 1520
1/16 Rally
My Youtube
pietrvds
10.29.2011, 03:35 PM
Hey Knez, how do the shocks feel coz my LST's are pretty smooth and you kinda feel they're quality but do those shocks feel like quality or just so so....?
kinda wanting to buy beefier shocks and these are cheap but maybe they're also garbage? lolz dont mean to be offensive :) :)
