12.03.2010, 05:15 PM
Originally Posted by brainanator View Post
I run a 3S in my hongkong radio. I routed the battery wires to the top to a toggle switch so I can basically break the circuit manually. I was worried about draining it too far, but I found that even after 2-3 weeks of use the battery is barely drained and still reading around 11.5V.
I just pop it on the charger whenever I remember to. My radio also has an LVA that turns an LED red at 9V for NiMH. Never seen it red, but I assume it'll work as an emergency reminder for me.
I would however be interested in seeing your circuit.... :) if you have the time.
Your radio must require 8 NiMH cells then? If so, plugging in 3s lipo is a breeze. This is more for people with radios that take 4 NiXX cells. and still want to use lipo. But since 1s lipo is too low, and 2s lipo is too high, a regulator is needed. I personally like the peace of mind knowing that the cells aren't being drained too low.
Yeah, I'll post the schematic, but I have to redraw it out since it's on scraps of paper at the moment. I also want to clean it up a bit.
What about using one of the switches the punk dig has (google it) ?
Any way of keeping the existing on/off switch with the other off being an over-ride in a LVC.
I don't know how the dig switch would be used in this application. From the looks of it, it just decodes CH3 pulses and locks the desired motor by shorting it.
Things will probably make more sense once I post the schematic...
