josh9mille
josh9mille's Avatar
12.05.2010, 12:05 AM
Originally Posted by thzero View Post
You've got completely overboard. I am positive no one singled any packs out for any reason.
And actually its not worse than MaxAmps, not even close. Its far better than MaxAmps because AT LEAST THEY ARE TRYING. Think you can do better testing with better methodology? Then do it. Don't like their methodology? Then start a civil discussion, not a bunch of name calling. Geesh.
Actually i do think they are biased against Turnigy. There are 2 most talked about lipo manufacturers and they are Turnigy and Maxamps. Maxamps is a sponsor on their site, which is why they have never tested a maxamps pack. In the test they even said some smart ass comment about the "cheap turnigy packs"
Turnigy 4S 4500- Anyone that says “Turnigy packs are every bit as good, and cost 1/3 the price!” hasn’t looked at the numbers. The Turnigy did not put out the voltage of the other batteries in this test. The lack of voltage will show itself as less speed when drag racing your neighbor and while trying to clear the big triple at your local track. Temp at the end of test was 89F, it put out 4495 mah, in 541 seconds (barely over 9 minutes).
Just the way they are talking about the Turnigy packs you can kinda tell they are biased against them.
