Post your Castle 1717 setup here!
sikeston34m
sikeston34m's Avatar
Post your Castle 1717 setup here! - 12.03.2010, 10:27 PM
Hey Guys,
I've been researching different ways/setups to put the power of the 1717 to good use.
A truly awesome motor, this thing must lay down some rediculous power.
I've been considering the Cen Genesis as a good playhouse for the 1717.
Please post your Castle 1717 setup here. Vehicle information, gearing, esc, batts, plus anything that would be helpful to those of us considering new setups. Pictures are a plus.
Thanks.
12.03.2010, 11:41 PM
I have a lst with the 1717, MMM, and a turnigy 40c 6s 5000mah lipo. Geared for low 40s, and using the stock lst2 tires which are 6.5" tall or slightly more and are quite heavy. Too much power, could be geared up quite a bit, although I wonder if the esc will keep up. On 8s with the MMMxl (omgwtfbbq) with lower gearing this would be plenty to move the big cen tires. I doubt the genesis would be much more than 3lbs heavier than my lst. Still a big truck. A 1527 would be my choice, but those are expensive...
I will be going back to the 1521 1y in my lst, and using the 1717 in the 6x6 lst. I have a feeling the transfer diff case will not take the beating, so I will have to machine up a suitable replacement.
bryan
bryan's Avatar
12.04.2010, 02:09 AM
[U
Here 's a pic of my xxl w/1717 MMM.I currently run this big rig on 5s, but 6s is in the works.My current 5s gearing is 20/63.Note i still havnt ran it with these big azz cen tires yet.The Moabs that i was running before were not much smaller so i should still be in the ballpark .
andreazinno
12.04.2010, 03:05 AM
Here my Savage with 1717, mounted on a custom made motor mount
Bye, Andrea
armourbl
12.04.2010, 11:58 AM
Here is my Caster F8T conversion with a 1717 motor. It was a tight fit and I had to use an EliteRC motor mount and also shave down the steering post to provide enough space. Not pictured is a top plate I made to link the front bulkhead to the center diff to prevent chassis flex that would cause the steering post to hit the motor.
I've since sold the 1717 and I ordered 1518 to replace it. It was just too much motor in weight mostly. I would have kept it, but couldn't see a use for it in the near future.
Pics can be seen in this post. http://www.rc-monster.com/forum/showthread.php?t=28552
Here is a video of it on the track running on 4S. It was literally my first run with the truck.
http://www.youtube.com/watch?v=y4CV2k60svE
ben
DrKnow65
DrKnow65's Avatar
12.04.2010, 12:04 PM
Ben, that was some real nice driving. I'm impressed at the balance considering the weight of that 1717
maneba
12.04.2010, 02:29 PM
My setup
6S
66 spur
11 pinion
sikeston34m
12.04.2010, 04:49 PM
Originally Posted by maneba View Post
My setup
6S
66 spur
11 pinion
I LOVE your setup Maneba!
How does it run and handle?
I'm thinking about a setup like yours, only using a E Revo tranny, plus maybe some saddle bag type battery compartments.
The battery compartments would mount to the sides of the chassis. I believe this would allow for some really large packs.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.04.2010, 06:07 PM
XXL, 1717, M.M.M, 6s-3300 40C, 63/25, weight 14.9lbs
http://www.youtube.com/watch?v=LGQiT...eature=related
Savage DesertBoy-17 1717, 8s, 40/15 for 47mph
maneba
12.05.2010, 08:53 AM
I have small cogging. But i think it's a firmware problem of the MMM.
I need more power on startup. People using MGM with same setup doesn't have cogging problem (so they say). Today i'll try to upload one of the first firmware.
andreazinno
12.05.2010, 09:07 AM
Ciao Maneba, me too same cogging problems with MMM (v3, early version, that with connectors on battery side) and 1717.
Needed to downgrade to firmware 1.21 to solve it.
Bye.
bryan
bryan's Avatar
12.05.2010, 11:56 AM
I really like those custom chassis parts Bondonutz
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.05.2010, 12:02 PM
Thanks B, Still waiting on more progress at the shop ? With the Holidays and my bud being so busy with work I doubt we'll be seeing anything till after Xmas.
sikeston34m
12.05.2010, 12:32 PM
How's the temps on the 1717, pulling these big trucks around?
Great posts guys! Keep em coming.
maneba
12.05.2010, 12:41 PM
For my almost 7,5 kg baby the motor temp is barely warm after a good ride of 10 minutes of start-stop-wheelies on asphalt (with a lot of grip).
outside temp of 18 C°.
