Got to try.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Got to try. - 12.08.2010, 04:27 AM
One has to try something. You never know what they are going to do until you ship it to them. I have heard stories go both ways with MGM, so ship it to them and see what they do with it. What have you got to lose? Good luck with that.
SUPERMAXX YOUR LIFE.
drkdgglr
12.08.2010, 06:01 AM
I like the built-in telemetry function. I asked MGM which telemetry systems will be supported and this is the reply I got:
"We will add more telemetry systems asap but it also depends on telemetry producers if they provide their telemetry datasheet - after having datasheet we can add any telemetry system."
These data can be transfered (taken from the preliminary manual):
- main (traction) battery voltage (respectively voltage of lower cell)
- main battery current
- temperature of the battery (when is measured)
- rpm of the motor
- motor temperature (if measured)
- controller temperature
- BEC voltage
- BEC current
- BEC temperature
