12.09.2010, 03:11 PM
Originally Posted by Dj_Sparky View Post
Just curious. What motor is that in the pic? Think I could make out 1521?
And also, where'd you get that 2 speed pinion adapter? I really need to get some of those.
Motor is a 1521 1y finned. 1600kv and it has enough power to move my 12lb lst around geared for 45mph or so.
The 2 speed adapter is from the rcm store. Uses lst pinion gears, or (preferably) rcm pinion gears. The rcm gears are hardened and superior to the losi ones. Great products, tailor made for conversions like this!!! Thanks Mike! In your face Tower Hobbies!!!
Need to order some from mike, just want to make sure that the sizes I need will fit with the flux motor installed and not touching the rear center bulkhead.
