Obeast44
12.14.2010, 09:33 AM
Originally Posted by doo540 View Post
I just finished watching all three videos, I had a hard time not laughing thru the last two.
That guy either has really small head or those tires are bigger then the 8.5 inch dia ones on my baja. haha
So are we all thinking a MMM on 6s and maybe a Neu 1521 for power?
Is this drivetrain they same as the gas version?
Give me about an hour after I go get breakfast and I will get some pics up of the Front/rear suspension. I will also get ya the tire diameter. Along with the correct ride height. The tires are definitely not bigger than 8.5in diameter they are close to Baja fronts. Which I think is 6.5 inches diameter.
Bear in mind I currently have the gasoline version but all the applicable dimensions will be the same :)
Obeast44
12.14.2010, 10:26 AM
Ok, I took a few measurements for you guys that are interested. The wheels/tires are 6 inches tall and 2 1/4 inches wide. That puts them fairly close to 5B fronts. I also rechecked the ride height, I set it as high as I could with minimal pressure from the droop screws (yes it has them). I got a measurement of 2 1/4in.
As you can see in this pic, the gasoline version has ALOT more going on than the much simpler direct driven electric version. The huge 4-gear plate, the fuel tank, rollcage , radio box and layshaft aren't needed.
I dont see any caster adjustments, just camber and toe are adjustable from what I can tell. If you have any pic requests let me know and I will do the best I can with my crappy camera :)
