I'm using the axles off the LST too, hence the 8mm ID. I got them off of Boca as an econo ten pack (part number 99MR148-2RS-X10, cost me $9 for ten). I didn't bother looking for other dimensions since the price was so good. (:
Glad you enjoyed your cruise! Hilo is very pretty but the reason everything's green is cause it does rain a lot.
I know this may sound like taking a step back but has any one tried to put the stock lst diff in and use the stock axles? I know you wouldn't be able to change the cups and from the looks of it you would have to build the bulkheads around the diffs, but you also would have to mod the diffs. Also if anyone has done this do the axle lengths match up well? I have just finished up my lst diff swap after blowing through 6 diffs in my E-Revo and I am very happy.
