Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
Shonen
Shonen's Avatar
12.18.2010, 09:14 PM
Not sure about the Phoenix software, but the Mamba XL is up on Castle's website.
http://www.castlecreations.com/products/mamba_xl.html
Raydee
12.19.2010, 11:35 AM
Looks like a ICE 200 with a fan. It would be great if I could use the software on my ICE 200's so I can use them with my pistol radio's!
brian015
brian015's Avatar
12.19.2010, 02:58 PM
You can run your ICE 200 with a pistol radio with this:
pistix
Raydee
12.19.2010, 03:12 PM
I have tried the Pistix adapters and I can't get the throttle response correct. I can pull over 1/4 throttle before the motor will move. I also can't get the ESC to see full throttle.
brian015
brian015's Avatar
12.19.2010, 03:21 PM
Huh - I've been using a pistix for a while now with an ICE HV 160 with no issues. I didn't have to mess with any adjustments to get it to work - maybe I was just lucky?
Raydee
12.19.2010, 03:26 PM
Yeah I have had others tell me that too....bums me out that I can't get it to work. What radio are you using?
brian015
brian015's Avatar
12.19.2010, 03:44 PM
Just a simple Tactic 2.4GHz (I started out with a Spektrum DX2 but was unhappy with the range I was getting).
Raydee
12.19.2010, 03:48 PM
I am using a DX3R radio. Maybe I will try the new Futaba 4PL radio and see if that does the trick.
DrKnow65
DrKnow65's Avatar
12.19.2010, 04:10 PM
Raydee, you may want to see if you have a neutral band adjustment on your radio. I could see if it was set too high causing the issue you are describing :-)
Raydee
12.19.2010, 05:17 PM
I did calibrate the radio and there was no difference.
DrKnow65
DrKnow65's Avatar
02.15.2011, 10:55 AM
Well, I'm loving my Mamba XL, and being the impatient goof that I am, I am buying a Phoenix Ice HV 120 for my 10SC. I will run it on 8S with mechanical brakes and a 1515/2Y (1100kv).
It sure would be sweet if the Mamba XL software would work on this smaller version so I could ditch the mech brakes...
Jahay
02.15.2011, 11:14 AM
i dont think they will offer mech brakes for HV systems as they cant handle the spikes created by braking... hence they came out with car versions...
02.15.2011, 11:51 AM
You mean motor brakes right?
Jahay
02.15.2011, 11:57 AM
NO BRIAN I MEAN MECH BRAKES! haha no only joking... yea how did i do that?
Well im bloody exctited to just get my savage back up and running so i can get the ice hv 160 working!!! 9s on a 1520 is going to be stupid! If i blow one motor, i have another haha... thanks castle ;)
DrKnow65
DrKnow65's Avatar
02.15.2011, 12:02 PM
Well, if the Mamba XL is a ICE 200 12S capable controller with software that supports 8S and motor brakes, shouldn't an ICE 120 12S capable controller be able to use the same software for 8S with motor brakes?
