Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.05.2010, 12:43 PM
Haven't had anything over 120* myself, even after a hard bash on 8s. Def no complaints with this motor other than make sure your Lipos are up to it.
BIG-block
12.05.2010, 01:45 PM
So Bodonutz, you run your Castle 1717 on 8S? No issues. I was going to try eventually (when I get the MMMXL) but wasn't sure if it was up to it.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.05.2010, 02:31 PM
I'm geared for 47mph and the RPMs are right at the thresehold of max rpm and still runs way under max temps. Wicked torque and speed.
sikeston34m
sikeston34m's Avatar
12.05.2010, 04:16 PM
When a motor is rated for kv, isn't that an unloaded rating?
8S is what I have in mind for the 1717 also.
Between a little punch control and maybe a little torque control, tame the beast just a little to lessen those amp draw spikes?
What kind of timing are you running with your Bondo?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.05.2010, 05:22 PM
Loaded/unloaded rating- not sure
Default/normal Timing
12.05.2010, 10:41 PM
My lst got the motor up to around 140-150f with 20mins of hard stop and go and alot of tire slip. I bet this motor is a best on 8s geared down... I may have to try that in the 6x6!
bruce750i
bruce750i's Avatar
12.06.2010, 04:01 PM
Wow! Those are some great looking 1717 haulers.
Here's mine, Savage-X17.
MiamizFinest
MiamizFinest's Avatar
12.06.2010, 05:44 PM
Waiting for my 1717!!! ill have it in a street set up Muggy on 6S!!
Shonen
Shonen's Avatar
12.20.2010, 04:21 PM
I stuck one in my E-Revo.
It was rather difficult to fit. It required shaving a lot off the rear shock mount, and I also had to shim the transmission up with washers on the chassis so the 23t pinion could mesh with the 38t spur...the 36t spur causes more problems than it's worth, if you have a 25 or 26t pinion it will probably be ok. I also lapped the motor mount face to improve heat transfer but also move the motor as forward as possible, even if it was a miniscule amount.
Having ran my 1515 on 4s, the 1717's lower Kv makes the E-Revo a lot slower than I was used to, but much much more torquey, with less startup cogging (usually none). The 40mm fan on the motor mount keeps the temps way down...I doubt this motor ever saw higher than 120F. After most of our bashing/jumping sessions, it's barely over 100F. Currently running it on twin 4s 4500mAh Nano-Techs.
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1.8333333333333333
Other Ratio: 1
Spur Tooth Count: 38
Pinion Tooth Count: 23
Total Voltage: 14.80
Motor KV: 1580
Tire Diameter (inches): 6.1
Tire Ballooning (inches): 0
Motor Current Draw: 120
Motor Coil Resistance: 0.005
Spur/Pinion Ratio: 1.65 : 1
Total Ratio: 10.01895 : 1
Tire Circumference (inches): 19.16 inches (486.76 mm)
Rollout: 1.91:1
Total Motor Speed: 22436 RPM
Vehicle Speed: 40.64 mph (65.28 km/h)
Effective KV Value: 1515.95
KT constant: 0.86 oz-in/A
Motor Torque: 0.53 ft-lbs
Final Torque: 5.36 ft-lbs
Final Power: 1776 watts (2.4 HP)
Great videos guys!
