glassdoctor
TEAM FUSION
glassdoctor's Avatar
12.26.2010, 01:27 PM
I think you should first try a simple cycling process, before worrying about zapping, etc.
The voodoo tricks and zapping was going out of style somewhat with the later generations of nickel cells. The internal resistance and capacities were better with every new batch it seemed. I think only the on road and boat guys were still obsessed with battery voodoo.
The FLEX charging was for the nicd... IIRC it was not recommended so much for Nimh. Same with dead short storage... that was great for the old 2000 cells but nobody was still doing it with the 3700, 4200, 4600 etc.
To bring old pack back to life... best thing to do is cycle it... over and over. I recently cycled an 11 cell pack that I had not used in a couple years. It's not for an rc... it was for "overclocking" my 12v ultraviolet fluorescent cure lights (I do windshield repair... thus the "glassdoctor"). Did the same with a black and decker "wizard" 3.6v tool battery.
I used my Hyperion charger and cycled them both several times. The first cycle of the B&D battery was only like 150mah... second one was about 2x that.... and after 4-5 cycles it was putting out over 1500mah.... about 80% of a fresh pack. Not bad.
Sometimes old cells are just junk... and you won't get much out of them. And it may not matter how much they were used. I've had brand new cells that were never used.... but would barely take any charge after sitting a few years. Others were fine. Same with well used rc packs...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
