RC-NUT
RC-NUT's Avatar
01.02.2011, 09:47 PM
And fixing the outdrive cups falling off should be pretty easy. Mark where the set screws contact with the output shaft, then drill small dimples for the set screws to engage. Use red loctite and let it dry overnight before use
I'll have to give that a shot. I've tried smoothing the flat spot with a dremel as well as blue and green thread lock. I was affraid of the red loctite once I needed to remove it. I have really cranked the 2.5mm set screws too. It's amazing how fast they slip off. I wanted to try drilling a thru hole on the shaft and using an HPI set screw pin but I was affraid of weakening the shaft.
Thanks for the tip.
