01.06.2011, 07:06 AM
thanks a lot for the pictures you gave us all. I'm new to RC and the rail was my first purchase but i want my car to go faster than 45-mph. I spent hours on-line looking for passionate hobbyist forums like this, finally founded.
I ask my self this "without changing my motor yet how am I able to increased speed" the answer was: gear changing.
I read all the comments but cant seem to find the correct parts you used as your central differential assembly on you Rail. I know your spur gear is a 48t with many circle around its outer sides and your pinion is an 18t but i need it's brand name and part number please. Did you change your stock dog-bones to different ones since you measured different length's on your centre assembly. did you had more hoes done onto the chassis for the mount to fit fine on your 48/16 gearing?
you have mention something about using "Team Losi" part's but did some research on a possible "look a Like" and found nothing. Futhermore, a Center differential and mount
from some Kyosho Inferno fit fine? you lost me.
very sorry for my late reply but I relly need you help. Please!!!!!!!!!!!!!!!
Your truly, Jose.
{;-)3
