B-Money
01.12.2011, 05:11 PM
Another copy
hey,
for the motor mount i will get the one where the motor mounts above the CD.
As for the racing issue, i reckon i could get away with it as i can lock the diff and then if they say it doesn't have a tranny i'll just get another diff and diff mount and have the pinion driving the CD then that CD driving the other CD. I could then just put a 5hitty plastic case over it and say it's a transmission.
Also i doubt i'll be racing this at proper events as it won't hold a candle to the e-revo's. I will have this for bashing and racing if i get bored of the e-revo. I am hoping the CF gets here tomorrow or friday so i can work on it over the weekend. Though everything is on hold till i get the CD mount which is currently out of stock. Also with this build i'll have to get some custom dogbones or get some extended diff cups.
All of the stuff pictured above will be redone with CF. 2.5mm thick. The stock chassis is very weak and i would say not even tempered so i think the side rails are the backbone to the kit and give it most of it's strength.
I havent ordered the alu yet as i might change my mind and get the 1/10' stuff as it's roughly the same thickness as the stock chassis.
For the alu though i am sorta thinking of doing the lower centre plate with that or do a brace for the CF with that. This project is going to take a while and most of that will be waiting and thinking about how to do stuff.
