Originally Posted by Bondonutz
Buggy looks great, can you post a parts list plz ?
I bought the aftermarket 17mm hubs and their sloppy, hows the 810 hubs fit ?
De-anodized can looks good also, I did the same with a 1512 1800kv mill. I like the Castle green but in some Rc's just clashes to much. Silver is nice.
I run my 10T on 3s and NEU 1512 2550kv and it's a bulllet, you'll appreciate the light weight and power !
The loctite tape, is it clear ? It's probably very close to the Parma tape, badazzed stuff !
I tried to get all of the green off, as you can see there is still some residual left. I also attempted to polish it as much as possible.
I am not using the 810 hubs, these are old revo proline 17mm hubs that I had to dremel up a bit to get them to work, but they have zero slop and work great.
The loctite tape is clear without the red film and the stuff works wonders, I am a bit upset I never found it earlier.
As for a parts list this is the best that I can do:
Losi Ten T
RCM Ten T conversion
Castle 2650
Castle MMM
RX: Spectrum SR3100
TX: Spectrum Dx3-s
AE XP DS1015
Soon to have Sky Lipo 3s 40c 5000mah hardcase
Diffs: 70-100-30
Front and rear gold springs
Front shocks: 60ish
Rear shocks: 40ish
Wheels: aka
Tires: Proline calibers m4
Body: Losi 810
Wing: Losi 810
Specs:
Rear Camber: 1.5
Front Camber: 2
Rear toe: Stock (Fixed)
Front toe: 2
Ride height: roughly 1.15 inch
geared 18/52
All specs are rough as my set up gear is not professional.
