01.20.2011, 12:06 AM
Good info on the wheels, could you tell me the diameter with tires?
As for the dogbones hitting the hinge pins, that is an issue. I had planned to run the arms level at ride height, and allow for a very small amount of droop, not enough to cause interference with the hingepins. It is on road, so alot of travel is not needed.
