Bazzokajoe
01.23.2011, 06:07 AM
i thought the same.. was expecting it to be much tougher... Had been jumping it for a while before the camera came out but i still wouldnt expect so much damage...
was pretty cold tho :P
the servo saver spring will be replaced with a harder one and wound the hole way out so it absorbs more of the impact.
Rear bent driveshaft will be replaced and the rear brace swapped out for a cnc one...
No chassis kit, just the SCRT10 Motor mount and a cheap battery tray... otherwise all stock
was planning on switching to mikes scrt10 chassis kit at some point, and running with a truck body... like an extended hyper10tt.... or would the extended chassis kit work better for me?
