andreazinno
01.28.2011, 02:49 PM
Originally Posted by DrKnow65 View Post
Cody, are you saying that your XL has LED's???
My original never showed any flashes, solids, or any light at all until it was arcing (bright!)...
Yes, mine too.
It has the standard three color leds (when calibrating: green - forward, red - backward and yellow - neutral)
Bye, Andrea.
Thomas Porfert
Thomas Porfert's Avatar
01.28.2011, 02:58 PM
Originally Posted by Knez View Post
Just had a talk with someone from Castle staff and i was told Mamba XL is got On-Off switch and LEDs as i understood...also got the info for non warranty repair is 150$. Dont know with who i spoke but he was very nice! Thanks for phone conversation. I ordered from towerH Mamba XL, CC bec pro and CC quick connect wire.
Knez
It does have all 3 LED's, but it does not have a switch; sorry for the mix-up. I let Bernie know that it does not include the switch for future reference. Thanks!
Thomas Porfert
Tech Support
DrKnow65
DrKnow65's Avatar
01.28.2011, 10:07 PM
Well, I'll be staring into the shiny glow of those LED's in a few short hours as my replacement XL has arrived WOOOOHOOOO!!!
Kcaz25
Kcaz25's Avatar
01.28.2011, 10:37 PM
I wish there was a like button. I would press it.
jeffbarnum
01.28.2011, 11:28 PM
Great to hear that your back in action bro!!!!!
DrKnow65
DrKnow65's Avatar
01.29.2011, 02:46 AM
For my next magic trick I'll be stuffing a Mamba XL into a Losi 8 buggy
With a Castle Creations conversion kit no less
blackz97
01.29.2011, 04:30 AM
Heres a screen shot of one of my logs. Can some one else post something similar? Preferably someone who is using some "nice" batteries. I want to compare the voltage dropoff (if any) of these turnigy (supposedly 40c sustained 50c burst) lipos against a higher quality lipos.
Link to full size screenshot
Knez
Knez's Avatar
01.29.2011, 12:00 PM
Thomas, no problem at all!
P.s: I forgot to tell/ask this CC staff yesterday...on ur site i think u got a word writen wrong... It says "Are u looking for something specfic?" Should it be "specific"? Just ignore if i am wrong... as English is not my language =)
http://www.castlecreations.com/index.html
Blue colored letters.
Flux 5B CC 1520
1/16 Rally
My Youtube
Russian:Life and Trust is Lost Only Once!
Thomas Porfert
01.29.2011, 03:35 PM
I would recommend also comparing the voltage ripple values. It will give you a better idea of how much you're "stressing" the controller and batteries due to the batteries amperage output capabilities.
Here's a link to a post by Patrick on ripple voltage: http://www.rc-monster.com/forum/show...2&postcount=11
It explains what it is and acceptable ranges. Being that you're around 32 volts, anything below 2.2V is good, 2.3 - 3.2V is okay, 3.2-3.8V is marginal and somewhat risky, and anything above 3.8V could potentially damage the batteries and/or the ESC.
haha yea, that should be specific, I'll let the webmaster know on Monday so he can get that fixed.
Thomas Porfert
Tech Support
blackz97
01.29.2011, 08:44 PM
Thomas Porfert
Tech Support
I checked the ripple on the log and the Max during that session was 2.26. I just noticed though that with all the data parameters being logged the XL only logs 8 minutes of data (must be a memory capacity thing). I would like to try and capture the entire run so i can see how the pack behaves at closer to LVC (25.6V). Thomas, would you say that the "Ripple" is the most important data to monitor regarding a batteries ability to supply the required current?
Steve
DrKnow65
DrKnow65's Avatar
01.29.2011, 09:41 PM
It was said that the ripple won't change much over time, so I'm not sure once the setup is "set up" that you need to check it regularly.
You can change the frequency/resolution of the data log in the parametrs to capture more minutes of your run.
I would say IMHO that battery voltage drop at the highest current rating is the single most important factor in showing battery quality.
I.e. If you floor it with good traction does the minimum voltage stay a few tenths above the LVC?
01.29.2011, 10:14 PM
Yeah, find your highest amp load and see what the voltage is doing. If you are above 3.5v per cell your batteries are doing well.
With these large scale heavy conversions I can imagine looking at the lowest voltage during the run will be the determining factor. Will weed out the "boys" from the "men" lipo-wise.
01.30.2011, 02:13 AM
Can we get some ESC/Motor combos to Monster Mike so I can buy one from him?
blackz97
01.30.2011, 05:35 AM
Heres more video. Sorry for the crap camera angles.
http://www.youtube.com/watch?v=ETy8lPMTGEo
01.30.2011, 07:20 AM
Hey. What's with the crap camera angles?
