02.03.2011, 12:45 PM
Originally Posted by asheck View Post
Have you managed to tear anything up yet?
Given the terrible weather I have only managed 2 half pack runs. Still pimpin the 12c lipos, not doing too bad. It is 45 or so here and the packs have not gone over 100f. Nothing broken, yet.
Sway bars on your Stampy;
See how the chassis has 2 tiny grooves just behind the front shock tower and the 2 empty 3mm holes. The grove is for the bar and hardware holes for the hold down screws.
This should be behind the rear shcok tower as well on the diff case. Sway bar kits are readily availible via fleabay
http://toys.shop.ebay.com/Toys-Hobbi...slash&_kw=sway
Thanks dawg. I will get some more wheel time and see if I really need them. I do notice the inside tire lifting under hard accel and brake, so maybe i should give them a try.
