If you are using an air ESC, you won't want a center position on the throttle. Also, brakes will be difficult to use unless they are mechanical and on a different stick. It's just the way air controllers and ESCs work.
If you do want a return-to-center spring for the throttle, you will want to use a car ESC. I'm not even sure if an air ESC will arm if the throttle is centered.
