Originally Posted by E-Revonut
Been awhile since I used the calculator, I noticed a few changes. You took out the 1/8 buggy & truggy typical diffs and replaced them with RC8 and RC8T. There is a problem with this, the RC8 buggy uses a typical truggy diff ratio 4.3:1, so if someone uses the calculator and doesn't know this they may have a problem
No, the "typical" diffs are still there. Look under "miscellaneous". Or, type in "typical" in the search field in the drop-down.
Originally Posted by silentbob343
Hyper Mini STE
3.9 differential
41 stock spur
I can add that, but what are the actual tooth counts for the diff gears?
