Been a while since the last update, but I've been making some progress as time and budget allows.
I got some hub extenders to finish off the arm assembly. I got some +15mm, as well as
+30mm hexes. The +30's really push the wheels out, and are mounted in the pix below. To make the ofna hubs work on the mugen axles, I had to file down the inside flanges (where the hub meets the wheel bearing) down from .5mm to .2mm. Even then I had to use 2.3mm pins instead of the std 2.5mm pins. At this point I'm not going to worry about a small loss in str. I can trim down the hub a bit more to fit a bigger thru pin, but I would have to trim back the whole hub, not just the bearing flange.
The width looks good now. I'm not really going to worry about too much extra bearing wear, as the stock mugen hubs look about +15mm anyway, and the bearings are only $1ea from Avid.
Don't mind the front toe out. I know its way off, but don't care for now. don't mind my son's Thomas track either lol.
I also fit the Mugen arm braces to the Savage bulkhead in the rear. Is allows me to use different toe plates to adjust toe and anti-squat. Cool. I did have to completely remove the remaining material in the bulkhead that was for holding the hingepins. Now the pins will be completely held by arm braces ala truggy style. I will have to mod the arm braces slightly, as well as the Sav skid plate to make everything fit.
The original holes are for 3mm screws, the Sav uses 4mm. The screw hole alignment between the Sav bulk and the mugen brace are only off by ~.2mm. Easy enough to adjust for when widening out the mounting holes.
I want to recess the front arm brace (made from 5mm 7075) onto the two 4mm screw posts on the flm bulkhead. (seen in the previous pix, underneath the drive pinion.) The posts are 7.1mm tho, and I need to get a drill bit that is close.
I also started cutting the shock towers from 0.25" 7075 alu. Holy @#$% that material is tough. My saw would zip right thru 0.25" 6061, but it cut
very slowly thru the 7075. Got all the way around the outer template, then my band saw threw the tire. Eh, I was waiting to replace it anyway, but sucked it did it right there. Otherwise I'm happy how the tower came out. I tweaked the design a bit from last time, and added body mount holes to use either the Mugen body mounts I have, or directly bolt Revo body mounts to the tower. The Revo mounts have always been very tough, so I'll likely go with those, plus I have lots of spares. The oem savage body mounts always broke on me.
Not too much work to be done until after Xmas. Need to repair the saw as a top priority.
