Cadtech
03.13.2006, 01:02 PM
Originally Posted by RC addiction
go with the flm any lighter than stock and you might as well put wings on it, i have the novak bl (i think is the entry level bl sys) and at the local track i can't keep it on the ground you have to find a happy balance between weight and traction
I agree about weight vs. traction on a BL rusty! I designed/milled my own graphite/G10 chassis and shock towers for my rustler, with Novak SS BL and it's tough to put power to the ground, or keep the front wheels down to turn.
Takes a delicate touch on the trigger finger.
If you track race, I'd recommend the G10 chassis. If you're bashing, the G10 would be good, but definately use a self-adhesive lexan film protector on the bottom of the chassis! The G10 will gouge fairly easy, which will weaken the laminate.
The FLM would probably give you better stability (more weight) for bashing.
http://community.webshots.com/photo/...1005726QSpvMd#
