Originally Posted by thzero
Did you resolder the with a higher guage wire on the micros? I do have a MicroPro running around I could use.
No its normally the other way around - skinny down the wires to 16ga or less to save weight...
PS Word of caution - Using Micro Pros is considered edgy on 3s with a 35T motor... Just be careful about what your setup is.
No way I would use one on an LCC or a single Micro Pro on an MOA or even an AX10...
I'd really only use Dual Micro Pros with an MOA rig or a 1.9 crawler.
