BIG-block
02.26.2011, 08:09 AM
Originally Posted by brian015 View Post
I wrap them in aluminum foil, put on a cookie sheet, and like my mother always said, when in doubt bake at 350F. Twenty minutes should do the job, but if not - bake some more. I definitely recommend doing this when the wife isn't home, since kitchen will smell a bit of burnt rubber.
Also your dinner might taste like rubber too. Not sure how you will explain that to the wife.
Originally Posted by alport View Post
Is acetone safe for the foam and the rubber of the tire? I used to boil my tires but searching for a better way.
I had some foams react very badly and some not too bad. Some swell up to roughly double the size and then shrink back once the acetone evaporates. You are just going to have to try it and see really. As far as the rubber and plastic wheels go they will be fine but most of the time the chrome finish will just flake away.
