pinkpanda3310
pinkpanda3310's Avatar
03.03.2011, 08:58 AM
The screw extracter set is a good one Jerry. I have one or two ezy-outs but almost never use them as I opt for the dremel.
Josh did you find that elusive spot with your tool? Gee!
vader2728
E-Maxx Breaker
vader2728's Avatar
03.03.2011, 09:46 AM
Patience. My best "tool"...
So that's what all the fuss was about...
bigsteel
03.03.2011, 09:51 AM
I really need to pick up an extractor set,with how many rounded out allens my 5B has I'm bound to need one soon
After about 20 mins of mindlessly fumbling around I managed to get it
pinkpanda3310
03.03.2011, 07:31 PM
I exercise patience but it's more of a 'have to' wait for parts.
Originally Posted by TexasSP View Post
The little traxxas T wrench that comes in there RTR's is one of my favorites. I use it quite often on all my vehicles.
Me three
I also always have a chunk of 2x4 laying around, I have a couple holes drilled in it for holding bullets upright while soldering, I do all my soldering on or over it to prevent burning my work bench. It also doubles as a car stand for my carpet car, it has been very useful many times in many different ways.
I use a saw stool too.
Too beefy, huh...
I think he's referring to previous activities. Must smell like $h1t.
You could use the dremel to cut slots in the screw head and use a flat head screwdriver if you think it's going to strip.
It took you 20mins!? I would have lost interest by then.
If I'm doing a lot of cutting with the dremel I will often use a 4" grinder to do the bulk of the work. Along with that - a file and sandpaper. Tappers for threading and rethreading holes. Calipers.
bigsteel
03.03.2011, 07:56 PM
Nah,it took a double dose but linc was good and passed out. He should check for pills in the next pie I make him.
florianz
03.08.2011, 06:12 AM
double sided sticky tape, the heavy duty stuff. I've mounted rx, esc with it. the esc is right on the chassis, for a low cog. never caused any problems.
these screw removers are great, surprisingly it works:
http://www.conrad.de/ce/de/product/8...AUSDREHER-SATZ
a small gas lighter to get screws removed, which are secured with loctite
http://www.conrad.de/ce/de/product/8...archDetail=005
gripping pliers are always good to have.
Useful tools
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Useful tools - 03.08.2011, 12:25 PM
VELCRO is a must have.
I also use a small propane torch for doing hot work like shrinkwrap stuff.
A small drill press is also a nice tool to have around the shop.
SUPERMAXX YOUR LIFE.
