So I've always had good luck with SPC packs, and they have lowered their prices to be very competitive, so I'd thought I'd post up a little info.
http://www.spcracing.com/index.php?categoryID=13 I currently only have the 8000 20c 2s packs, but will have a pair of the 6000 30c hardcase, and they have some new choices coming, including a 3s 5000mah 40c, that I'll be getting.
Here's a 6000mah run, out of one of my 8000's, it's about a year old, with 40ish runs, mostly in my E-revo under heavier loads, so it can't be 100%, never kicked the 3.2v LVC, though it did drop to 6.15volts, late in the run, under 117 amp load, so that translates to 14.5c.
Anyway, kinda nice to have a choice, available from the US, that performs as rated, you get to pick your connector, and if anythings wrong when you get it, just send it back.
BTW when I get my new packs, I'll post some fresh logs on them. I have some other packs that will make some interesting comparisons.
