03.14.2011, 09:35 AM
And to add, if you are running metal on metal gears you can set the mesh by sound. If it is loud it is likely too tight, so add some space till it quiets down a bit. My only metal on metal gear setup is on an lst, and the tdr racing mount makes it real easy to dial the clearance in or out.
