What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
03.14.2011, 09:47 PM
Honestly, I'd stick with the wall charger that came with it. If you really want to use the other charger then stick to a 1C charge rate (0.6 amps). The charger will work fine- no balancing is needed when charging 1s and the CC/CV cycle is the same.
