03.17.2011, 01:20 PM
Ok, a little info about the sky lipo 2200mah 40c 2s pack.
I have not done a timed run to lvc yet, but this is the result of my 1st run.
Lvc set to 3.2v per cell.
Coming out of the car the battery was not over 95f, ambient was around 65f.
Voltage bounced back up to around 6.6v after a min or so.
After charging the pack took in 2163mah, and charged for 63.41mins at 1c charge rate.
I usually do not run to the lvc, I stop when the performance drops off. Per my experience this is usually 60-90 seconds before the lvc kicks in. Felt about the same on this pack. The pack was out of balance after the run, so I may have drained it a bit much. I plan to set the lvc to 3.3v per cell, and I will stop when I feel the performance has dropped off. I will say that the pack had plenty of punch all the way till the end.
I could not be happier with this $12.50 lipo. I do plan to try it out with the cc6900 motor I have coming. Not sure if it will hold up to that motor, but we will see.
