nastety92
03.20.2011, 05:02 PM
Originally Posted by scarletboa View Post
The superbrain charger has an external power supply with 4mm bullet outputs I believe. The hobbyking Eco 6-10 charger's input wires have alligator clips that have 4mm bullet inputs, so you would not even have to do any soldering to use your current power supply with it. If I were in your situation I would get the Eco 6-10 charger and just use your current power supply with it. For charging 2 batteries at the same time, just get a second charger and either a new power supply or make a parallel adapter so u can run both chargers off the one power supply.
Originally Posted by x-y View Post
the eco6-10 is a great charger ........ I have 3 and works perfect ......... :D
Thanks for the help guys I'm going to grab one of these soon and I might as well get a few more lipos as well. Maybe some 4s this time.
Nick
