Thread Tools Rating: Thread Rating: 6 votes, 4.17 average. Display Modes
bruun
07.15.2011, 01:04 PM
recieved the universal cd/motormount 2nd edition, and it looks beefy and well made. here is a couple of mock-up shots
Name:	cd mount 002.jpg
ID:	10071   Click image for larger version
Name:	cd mount 003.jpg
Dj_Sparky
07.22.2011, 11:10 PM
Very nice. I've been considering buying a universal CD mount from Mike for my Emaxx.
And does anyone know of some good, very long wheel wideners for E-maxx that are very sturdy? I don't want to use the Integy 23mm ones.
07.23.2011, 01:36 PM
http://www.neweramodels.com/item.cgi...=&part_id=2963
http://www.wheelextensions.com/index_files/14mm
http://www.junfac.com/shop/index.php...f071ae71433b16
You could also use these:
http://cgi.ebay.com/Pro-Line-23mm-He...item2eb5ed65b0
or these:
http://cgi.ebay.com/Ofna-30059-17mm-...item45fba835fc
But you'd need a sleeve over the axle to take up the slack- 6mm axle vs ~8mm inside diameter of the extension.
If you were using the teknorc knuckles with the 8mm axle option, they would be a direct fit...
http://www.teknorc.com/product_info....roducts_id=988
I suppose you could just use the optional stub-axles, but then you'd have to find some odd sized outer bearings to suit the stock knuckles.
http://www.teknorc.com/product_info....oducts_id=1083
stock is 6x12x5, you'd need 8x12x5- a quick google does turn up some results so it is a possibility...
Dj_Sparky
07.23.2011, 05:44 PM
Very nice, thank you. I did not know of the wheelextenders site, but I think I actually have a pair of those and was wondering where they came from.
bruun
09.23.2011, 07:43 AM
It`s done (for now) here`s a few shots
ID:	10146   Click image for larger version
ID:	10147   Click image for larger version
feistyacorn
feistyacorn's Avatar
09.23.2011, 10:42 AM
Very Nice, looks like a good time!
Bosox06
09.23.2011, 05:06 PM
You truck looks amazing, The gorillamaxx trucks handle great with cd mounts. I did mine a little different i wanted the motor to sit down a little more so i mounted it more towards the front.
Photos????
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Photos???? - 09.24.2011, 02:12 AM
Where are the photos Mike? All I see are two boxes with little red "X"'s in them. Your vehicles are always a treat so I would love to see what you have to show off this time.
The project looks geat. Good work.
SUPERMAXX YOUR LIFE.
Bosox06
10.05.2011, 05:33 PM
Does this Pic show?
bruun
09.23.2011, 08:03 AM
A few specs: castle 1518-4s lipo 5,0A 35c-spur43t mod.1-pinion 14t mod.1
cmac
cmac's Avatar
10.05.2011, 07:01 PM
Man that looks awesome!!!!!
WEB
10.05.2011, 09:49 PM
Gee done a good job of that mate good stuff!!
bruun
10.06.2011, 03:05 AM
WOW that is one sweet ride
bruun
11.29.2011, 07:21 AM
Actually I like yours positioning better, is there romm for an ESC behind the motor? or will it require the monoblock ext.?
11.29.2011, 04:00 PM
Easily enough room for the esc, unless you had a massive long motor like a neu 1527. Compare this similar build:
https://picasaweb.google.com/1123338...RevoCenterdiff
The 1515 sized motor stops where the rear-upper chassis plate begins, so plenty of room on a maxx-based truck.
