Thread Tools Rating: Thread Rating: 6 votes, 4.17 average. Display Modes
Center diff in my G2R maxx
bruun
Center diff in my G2R maxx - 03.23.2011, 06:06 AM
Hi guys! I have been following your forum thread`s for a while-enjoyable reading Now I´m in the progress of removing my gearbox on the old G-Maxx and want to put in a center diff, since the gearbox isn`t holding up well against my NC1520. But could you guys plz help my out with this? I bought a CC losi conversion kit, as I couldn`t get a hold of Mike`s uni center diff/motor mount, then I bought a Losi smartdiff to drop in there-but even with the 46T spur it won`t fit inside the g2r chassis. any suggestions as to what spur/diff i could use?? don`t want to cut my G-maxx chassis.
Here are some older pictures of the car:
http://rcgalleri.dk/html/gal_visbil.asp?ID=29957
Welcome to rcm.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Welcome to rcm. - 03.23.2011, 06:24 AM
Sorry not able to check out the pics without joining that site. I am on several sites already and do not have time to join even more. If you would like some help with your project then post up some recent pics of what you are doing so we can assess the situation and give you advice.
Welcome to RCM and enjoy your time spent here. There are plenty of great people in here who have lots of knowledge and also tons of experience with your type of project. Good luck with that.
SUPERMAXX YOUR LIFE.
JoFreak
JoFreak's Avatar
03.23.2011, 06:57 AM
Try a 44T spur gear. Mike has/had Kyosho spurs in his shop. They fit between the x-braces of the G3, so it should fit in the G2R as well.
bruun
03.23.2011, 01:50 PM
sorry about the link, as it is the danish site i normally visit, i am allways logged in-didn`t think about what it looked like for you guys. I will post some pics off my progress/ troubles soon
feistyacorn
feistyacorn's Avatar
03.23.2011, 02:00 PM
I’m using Mikes center diff mount with a 46 tooth Slipperential on a G3R. There must be something different with the Losi diff. People usually don’t recommend the smartdiff for brushless, something to do with durability I think. Maybe you could try contacting him to run another batch. If enough people asked again, I bet he would do another run.
ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
03.23.2011, 04:33 PM
Losi Makes a 43t Plastic spur for the 8e. I guarantee that'll fit between the braces and on the smartdiff. The Kyosho always leaked on my 8ight diff...
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
bruun
03.24.2011, 03:48 AM
Thanx Zippybasher, will try the 43t plastic. I have email`ed Mike about the cd/motor mount. will wait a while for reply. I will now try to post a few pics
ID:	9831   Click image for larger version
ID:	9832   Click image for larger version
latest update
bruun
latest update - 05.03.2011, 03:01 PM
now running 6s on a CC1520 with 21/70 gearing still with original gearbox.
ID:	9910   Click image for larger version
ID:	9911   Click image for larger version
bruun
05.11.2011, 08:15 AM
A little video here http://www.youtube.com/watch?v=dAxb_EAO0Ws
Not bad
JERRY2KONE
JERRY2KONE's Avatar
Not bad - 05.11.2011, 10:56 AM
Not bad Bruun. Considering the handling it looks like you need a UE Mono-block to lengthen the chassis a little bit, and you may want to condsider installing axle adapters to widen the wheel stance just a bit as well. You just have a lot of power for such a short package. Nice looking ride though.
bruun
07.10.2011, 06:15 PM
I have been looking at the UE Mono-block, but i`m actually quite happy with the truck as is. It have been geared down to run approx 55kmh. I am going to install the RC-Monster Universal Center Diff/Motor Mount, which I just received as the 1520 tends to break the input drive shaft in my G1 tranny
Overdriven
Destroyer of Tires
Overdriven's Avatar
07.11.2011, 06:25 PM
If you do a search here, you can find a few examples of others who have done what you are trying to do. Welcome to the forums, and definitely post about your progress.
Edit: Running a SmartDiff in the center position with brushless is generally not recommended, unless it is a race rig. SmartDiffs require regular maintenance and even more maintenance (and parts replacement) is required with a brushless setup due to the increased power over a nitro setup. So be prepared for that if your going to use the SmartDiff.
bruun
07.13.2011, 03:12 PM
Thanx Overdriven, I have received the new RC-Monster uni cd/motormount, which is looking seriously beefy! and based on what You are telling me-(and the fact that the losi diff doesn`t fit) I will we looking for something else, Suggestions? the motor will be a castle 1518
07.13.2011, 03:18 PM
Any regular 1/8 scale diff should fit fine- I'd look at the ofna and hotbodies ones, very cheap on ebay and easy enough to tune ( to reduce wheelies ).
bruun
07.13.2011, 06:22 PM
thanx for a quickie
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
