hyperasus
hyperasus's Avatar
03.16.2006, 10:34 PM
Originally Posted by nitrostarter
I have a question on the 977 Charger that you guys offer. I was reading that it can charge 2 packs at once, regardless the pack size and type. It also says that it can charge up to 5.0Amps. My question is can it charge Lipo packs at 5.0amps and if so can it handle 2 lipo packs at 5.0Amps? Thanks for the help.
Cory
Hi,
The only time you would ever charge a lipo battery is if the capacity is 5000mahs. You must always set the charger for a 1C charge rate which will take 1 hour to charge. The 977 will only charge up to 3 cell for lipo packs.
John
This is an email from MRC Support that I questioned them on.
__________________
They didnt answer the question. Yes the battery is 5000mah or higher. Will it or will it not charge 2 lipo packs at 5amp each. Do these companies not realize that there are Lipo packs bigger then 5000mah?
