check these out!
mjderstine
mjderstine's Avatar
check these out! - 03.23.2011, 03:41 PM
http://cgi.ebay.com/5-sets-6-5mm-Bru...item43a2f1c7ba
these are some interesting bullett plugs.
they are like inside out male female plugs. i dont even know what to call them.
anyone ever try them. they are pretty darn cheap compared to the standard style.
whitrzac
Can't catch this...
whitrzac's Avatar
03.23.2011, 03:59 PM
I remember seeing those for $6 a pair a while back... IRRC it was hyperion...
I use 3.5mm HK ones on everything, including my 1/8 buggy(6s) and have never had a problem...
reno911
Smelly Nitro meet your maker!
reno911's Avatar
03.23.2011, 04:53 PM
XT-60?
I love them, easy to solder and good contact. By far my fave.
mjderstine
mjderstine's Avatar
03.23.2011, 06:03 PM
cool, nice to see you guys are likin them.
i might have to order a bunch since they are so affordable.
have you had any issues with the tips touching since that females end seems like getting heat shrink around it looks tough?
KaztheMinotaur
KaztheMinotaur's Avatar
03.23.2011, 09:38 PM
I'm wondering what the current rating is?
scarletboa
scarletboa's Avatar
03.23.2011, 10:46 PM
according to what i've seen and heard, they can handle just a little more power than deans plugs. if i didn't have about 50 pairs of knock-off deans plug lying around, i would switch all my plugs to the xt-60.
KaztheMinotaur
03.24.2011, 05:40 AM
I sent the seller a question asking what it was...should be interesting to see what he says.
03.24.2011, 08:43 PM
'Lots'
Allerc.com do sell some similar bullets, but I had issues with the shrink sliding down the connectors when I used normal 5.5mm bullets; I imaginer those would be even worse.
EC5 connectors ftw
KaztheMinotaur
03.25.2011, 06:09 AM
Dear kaztheminotaur,
hi friend;
so sorry to tell you that,we are not sure that,hope you can understand us.
thanks
have a nice day
- planemodel55 Click "respond" to reply through Messages, or go to your email to reply
To: planemodel55
Subject: ??: kaztheminotaur ? 5 sets 6.5mm Brushless Motor ESC bullet connector plug????290496563130 ???????
Sent Date: 2011-03-24 09??44?39?
planemodel55????
What is the current rating for these plugs?
- kaztheminotaur
mjderstine
mjderstine's Avatar
03.25.2011, 12:14 PM
awesome response there. but at least you got one. makes it almost werth the price
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
03.25.2011, 12:39 PM
I don't like them. I prefer the bullets with the female being like a tube and the male having the slots. Reason why for me is I like to cover the bullets with high quality heat shrink with glue inside. When the shrink is heated, the glue melts and the result is a better bond between the shrink and the plug's surface. But I do have to clean up the glue that seeps in the male plug's slots. Easy to do with a hobby knife on the standard bullets but it would be impossible to clean the slots on that female plug. If using regular heat shrink with no glue inside then it wouldn't be an issue.
No brain, no headaches.
mjosparky
Sparky
mjosparky's Avatar
03.25.2011, 11:10 PM
EC5 connectors, rated at 120 amps continuous and easy to solder even with 8 gauge wire.
http://www.hobbyking.com/hobbyking/s...idproduct=9194
Sharpchuter 245
Dyna Wide Glide
B-Money
03.26.2011, 12:08 AM
I recently changed all my connectors over to EC5's from Deans. I found that with the deans i would be pulling the wires not the connector but with the EC5's i am pulling the plastic housing. Also, the bullets are far easier to solder and recently i was having trouble with melting deans but this is not an issue with the EC5 bullets.
brainanator
brainanator's Avatar
03.26.2011, 12:59 AM
Where is the cheapest place to get EC5 females? (er...the ones that go on the battery side, I can never tell which is which on these housed bullet style plugs.)
03.26.2011, 12:08 PM
If it wasnt for shipping then Hobbyking would be cheapest ( female connector is the female bullet & the larger plastic housing that goes over the male connector as such ). Otherwise, probably ebay really..
