ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
03.28.2011, 07:24 PM
Chad - If and when you do find those Saver parts shoot me a PM with a price. I May take you up on that if the price is right.
Man I went and ran a pack through this weekend on the newly rebuilt diffs. CRAP, I locked/blew the rear diff on the first run. Nova cup actually failed. The pins that hold the 4 spider gears mashed into the sidewall on the Diff Cup. Therefore locking the diff and chipping some of the gears teeth. But you should have seen the "doughnuts" I was doing. It was literally like a Gyro, the faster I gassed it, the faster it spun. Spun so fast It was just a big blur. Crazy.
So new Bevel gears are OTW and I will just go back to the Losi HD cup (on the rear). What a shame. The CD is holding up OK.
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
mothman
03.30.2011, 07:55 AM
Wow.. u managed to cause some damage to the diff? How bad did you abuse the truck? I am very impress since this is the first time I hear about Nova cup failure. All this while I thought they are bulletproof.
ZippyBasher
03.30.2011, 05:29 PM
I thought the same thing about the Aluminum Nova Cups Being bulletproof. The rear cup is useless after 1 pack and I just took the CD cup out to refill with a lighter fluid and give it a thorough inspection and it actually is starting to wear pin slots in the side of the cup as well...(at least a dozen runs or so) I can try to get a picture but Its not that cool Well there goes $40.
I will just go back to the Losi XXL HD plastic cup. I looked at the one I was using for over a year in the rear diff and it looks new... the ring and pinion also look brand new. I guess those little metal inserts in the XXL really save the cup. I think a CNC cup designed after the XXL cup would be bulletproof, but not cheap to get CNC'd...
D8T - MMM 1717 6s
