Overdriven
Destroyer of Tires
Overdriven's Avatar
03.29.2011, 04:56 PM
If you have a drill press you're better off taking the rotor out and using the drill press to spin it, no debris gets in the bearings then. Just mark the shaft where the bearing rides so you don't go too far.
You have enough room in between the TVP's for a 56mm diameter motor? Leopard has a few other 44?mm diameter motors in long lengths with various kv's that might be easier to squeeze in your chassis.
