What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
04.15.2011, 07:19 PM
Haha Linc... Off the top of my head the wiring is like this:
Black - (-)
Orange - "C" Sensor out
White - "B" Sensor out
Green - "A" Sensor out
Blue - 10k Resistor connected to (-)
Red - (+)
The 10k resistor bypasses the thermistor that is usually in the motor. I did have to sand the sensors to an angle in the setup you see above to clear the can of the motor. I've solved that problem with the new array by using a piece of body lexan between the sensors and the endbell.
