04.19.2011, 09:25 AM
The BEC does not connect directly to the servos, you simply plug the BEC into channel 3 on the receiver and the servos pull power from the power rail in the receiver.
Dremel the tinned ends until they fit. You only have to remove solder, once down to the wires it will fit. I just did this with my Mamba XL, with no problems whatsoever. Don't worry about bottle necking.
