el tomaso
04.30.2011, 02:45 AM
Since the hyper st is so narrow, I used mbx6 mudguards to widen it for more battery room. Then I used the RCM D8T tray, IMO a poor fit, had to file a lot under the tray. I think the RCM mbx6t tray would be better but now its ok with the modified tray.
You could also stand the battery o n the side in a narrow tray. A little higher CG but much more centralized weight. Then I would custom order it to your specs from RCM.
Thomas G
