Aussie Nerd
05.06.2011, 10:50 PM
You know you're hardcore when you haven't even used your ESCs but they are already under the knife. Straight from the packet the case was removed, the white wire desoldered, switch removed and soldiered so it is permanently on at the board and then heatshrunk. From my rather inaccurate scales it is around 5-10g lighter per ESC.
Also I got a picture of the bad shock shaft, this is what you DON'T want your shafts to look like straight out of the packet. Not the clearest picture, but enough to get the general idea.
Slowly getting there...
Kieren
