Go Back   RC-Monster Forums > Support Forums > CORR Trucks - Slash, SCRT10, etc.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
05.11.2011, 03:18 AM
Waiting for photos to upload to photobucket, I'll post a couple and the link to the whole album. This is my first actual build from a kit. My RC8T was complete when I bought it but I had to tair it apart to convert it to brushless.
The build took me 6 hours, only thing that isn't done is the body. There where no major issues with the build, for that matter the only issues where my own! I do have a gripe about the instructions though. Although the build is in alpha order of the bags of parts it'd be nice for them to tell you what bag your working on. Also I wish there was a 1:1 referece in the of the screw size in the instructions. When you open a bag for a step and there are 5 different size screws and some are only 1mm apart it gets screwy! The only issue I had was that I accidentally did the shock towers in the wrong order, grabbed the wrong bag and didn't know it. The rear tower will almost work on the front and it took me about an extra 10 minutes of messing around to figure out that I messed up. Fit and finish is awesome and the truck look like a tank!!! This truck reminded me of a 1/8 buggy as I was building it. The parts are all pretty good size for 1/10 scale.
The shocks, diffs, and some of the front suspension all came pre-built. The diffs actually had silicone oil in them rather than grease. However they weren't very full so I added some 5k to the front and 3k to the rear.
The suspension arms are not side specific, a quick flip and they'll work on either side which is very nice for spares, they are different front and rear though.
There was some thinking ahead done with this truck. There are lower body mounts that look like they'll be used for an under tray and there are spots on the A-arms that look to be for a sway bar kit.
One question I was dying to find out was if the body was any different than a base 2wd SC10 for mounting purposes. A 2wd SC10 body does fit, it's not a perfect fit without a little trimming but easily workable, just a little trimming for the front bumper. The post holes are off just a touch but the body easily flexes enough to acomidate that and after trimming for the front bumper it may fit perfect. It's nice to be able to use the bodies I already have.
I took it out for a quick test drive and was pretty happy, not that I could do much at 2:45AM though.
Setup: MMPro esc, 1410 1y CC/Neu motor from the sidewinder SCT combo (I may even give the sidewinder esc a try and save the MMPro), Hitec 7955TG steering servo. Kit comes with two spur gears to give you the option of 48 or 32 pitch. I'm using 48 pitch for now because I have a wide selection of pinions to use and I know that with a properly setup gear mesh I'll be fine. My base gearing is the stock 93t spur and a 21t pinion and I'm using the optional gearing to give front overdrive.
Pictures to follow
