Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
himalaya
himalaya's Avatar
10.16.2009, 12:22 AM
Originally Posted by Unsullied_Spy View Post
I've heard these motors are quite expensive, nearly as much as a Neu. I'd rather have my money go to Neu than some Chinese company any day.
Chinese products are not likely to stay at the super low end forever. They'll natually be going to have better quality and ask for a fair price, like the Japanese did decades ago. You know Steve Neu uses Chinese magnets, so will you buy a Neu? The thing that matters to me is not where the motor is made, but how it works.
....What a Blue Sky....
Unsullied_Spy
Unsullied_Spy's Avatar
10.16.2009, 12:26 AM
Originally Posted by himalaya View Post
Chinese products are not likely to stay at the super low end forever. They'll natually be going to have better quality and ask for a fair price, like the Japanese did decades ago. So the thing that matters to me is not where the motor is made, but how it works.
These motors are, supposedly, quite good. It's not about quality, I'd rather drop money on a domestic product if I were going to spend that much. I love the cheap Chinese motors because they're cheap and they work (for the price many are quite good) but if I am going to drop hundreds of $ on a motor I'd keep that money in my own economy than send it overseas.
drkdgglr
10.16.2009, 01:10 AM
the price depends on where you live and were you buy the motor. If I buy a new Neu, i'll have to add about $30 for shipping, 19% tax and some extra custom duties.
products from hk usually get past customs easier and shipping is cheaper. For me the tenshock would have been the same price as a 60-70mm medusa.
edit: I would end up paying a total of $340 for a new finned neu 1512...
drkdgglr
10.16.2009, 05:12 AM
Had to take the motor out because the rear came off, so I took some pictures of the rotor:
lutach
lutach's Avatar
10.16.2009, 08:32 AM
Is that rust or some sort of coating?
scarletboa
scarletboa's Avatar
10.16.2009, 07:56 PM
the first picture almost makes it look like the magnets are wooden
that rotor don't look too healthy
10.17.2009, 06:28 AM
Clever way of preventing the magnets from comming loose, but they look like pepperami sauasages to me...
florianz
10.21.2009, 02:34 AM
that's right.
Most "rare Earth" Magnets like neodymium do come from china. The german manufacturer Flyware (good brushless motors) get their magnets from china. Most or probably all nimh batteries come from china; IB Intellect Batteries are chinese, and are they crap? And almost any Lipo is manufactured either in China or Taiwan.
It depends on the quality assurance, if a chinese product is crap or not. the german slot-car brand "Carrera" have moved the assembly from Germany to China some years ago. After some problems in the beginning, they now have just excellent quality.
Sooner or later china will be a problem for both american and european brands. Because we rely on the fact that we're good... but things change...
drkdgglr
10.21.2009, 07:52 AM
Things that justify the higher price compared to cheapo chinese motors are the fact that these motors are hand wound and each rotor is individually balanced. unfortunately it seems my eagle tree has died, so I can't provide any et data from running the motor.
adrictan
10.22.2009, 01:25 AM
Are there any for 1/8 truggy? 4-pole,6-pole would have too much torque, right? And most of their motors seem to have 4mm shafts. I'm looking for one that is abt 2000kv, 5mm shaft and not too torque crazy. 2-pole 2000kv compared to 4-pole 2000kv, the 4-pole would be very high torque, right?
drkdgglr
10.22.2009, 03:22 AM
The 22 series 6 pole motors all have 5mm axles. The biggest one in the 22 series is the 2250 which is rated for max 2500watt's. It's not listed on their site, but I've seen the car version of this motor listed in a webshop. Theoretically that motor should do well in a truggy.
I also just saw they have two 8-pole motors. The 2740 (45*59) which is rated for max 3000 watt's and the 2750 (45*69,5) which is rated for max 3800watt's.
adrictan
10.22.2009, 05:23 AM
I would like to see if someone is using it for 1/8. I know I have a local guy who's bringing it in direct from China but will let him try it on his truggy and buggy before I decide on things.
drkdgglr
10.31.2009, 06:14 AM
Just ran the tenshock with the mmpro. Geared 16/42 which is about 35mph without ballooning. Ran onroad, in the sand and in grass. Running off-road and in the grass temps slowly rose to 118f, and when I ran onroad the temps would drop to 100f. I didn't push the car offroad beyond 118f just to be safe. I don't think the fan on the mmpro ever turned on.
edit: didn't change any settings in the mmpro before running expet setting the lvc to 3.2v/cell. 50% brakes was a bit too much, changed it to 30% for the next run
crusey_aus
05.15.2011, 03:39 AM
Hello Folks,
Just did some testing of the Tenshock 6 pole motor X802 (2400kv)
Car Setup
Slash 4x4
Geared 21/52
Proline Streetfighter Tires (4.5" diam)
Trackstar 150 ESC
0% Punch
3s 6000mah 25c Turnigy Nanotech
Ambient Temp 55f
Theoretical Speed (scriptasylum calc) - 51 mph
Recorded data from an Eagletree v4
1st run
No motor timing
Temps after 10 minutes of high speed runs
Motor 120f
ESC 85f
Peak Amps - 177.5
Peak Watts - 1780
Min Voltage - 9.98
GPS Speed - 54.4 mph
2nd run
Added 16 degrees of timing
Motor 150f
ESC 95f
Peak Amps - 175
Peak Watts - 1801
Min Voltage - 9.98
GPS Speed - 55.5 mph
Not sure what to make of the fact that adding timing appeared to change nothing except raise the temps, was suggested that these motors come alive when its added
Not bad results though, quite happy with the motor, will push it a little harder and do some 4s testing soon
Cheers
florianz
06.02.2011, 02:41 PM
hi,
had my first runs with the x801 with 1900kv on 5s in my LRP S8 TX Team Truggy. It's supposed to be strong enought to run the truggy, and I have heard quite good things about the Tenshock motors.
Well, in the beginning it got far too hot, with the recommended high timing of about 18 deg., and later with 26 deg. timing. I think, gearing was far too big, too. my fault. ESC is a used HW ezrun 150a. Like that, temperatures were around 80 deg. c and more (185 f.), with timing of 26 deg. about 90 deg. C. I am using a fan on the motor.
I think, the timing and setup for a buggy is different then for a truggy, so I tried lower timing.
I was told that they are getting a bit hot, but that was far too much. So I have changed gearing to 16t, the same like with the Leopard 4074 2000kv. The leo always had around 55 to 60 deg. C, with fan (140f).
With lower gearing and lower timing of around 4 degrees, the tenshock got a little cooler, like around 65-70 deg C (158f). Slightly hotter then the leo. well, we had a worm summer day here in Hamburg.
Performance was good, quite similar to the bigger Leo 4074, probably a bit more torque, not sure. both have the same sized magnets I think. the x801 has a power-characteristik quite similar to the Leopard. So far, it is hard to tell if the x801 is that much better then the leo. the x801 is basically a 2240 motor. The x802 has more slots. There are also long versions available I think.
But that's just a first impression so far, and I have to test some options on the esc. I loved my xcelorin 1700kv, which war for sure not any weaker then the leo or the Tenshock.
For a buggy for sure a great and powerful motor, and probably for a truggy as well. more to come soon.
florian
