Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
brian015
brian015's Avatar
05.23.2011, 10:02 AM
Originally Posted by Bmr4life View Post
I've been considering purchasing a mill, but even for the small X2 benchtop size, I'm look at well over $1k for it and tooling. I wouldn't be using it often enough to justify the price. Finding ways to make stuff without it is my mission. You've definitely shown me a few things. Thanks
I hear you about the mill - I, too, can't justify that purchase for this hobby. So I've tried to do my best at fabricating parts with my limited tools - drill press, hack saws, files, dremel, etc. - by finding pieces of Al angle, u-channel, and sheet that fit my needs.
mjderstine
mjderstine's Avatar
05.23.2011, 04:51 PM
i too have cut many many things just with the hack saw. i built my SC truck completely with hand tools.
i found that when just holding onto the saw wearing a thick pair of work gloves on the saw hand works wonders for grip. and it also works better to flip the teeth and do the cutting on the pull stoke. since the blade is free it tends to bend a lot when pushing.
i also clamped angle stock to all my long cuts to keep straight lines.
brian015
brian015's Avatar
05.30.2011, 09:11 AM
I did some more work on one of my battery trays - they will have 1/8" Al angle at the front and back:
I also finished the front shock tower - cut down feet, sway bar installed, mounting holes drilled and tapped for m4 screws:
Bmr4life
05.30.2011, 09:47 AM
I saw those PVC channels you used and ordered some myself. The price sky rocketed after I ordered mine though.
brian015
brian015's Avatar
05.30.2011, 04:53 PM
I've seen the price go up and down dramatically on those channels - it's weird
brian015
brian015's Avatar
06.18.2011, 01:53 PM
I've been waiting on this part:
It's the Hobao Hyper 9e Steel Uni Center Drive Shaft (89339) and its overall length is about 8.5". It should work perfectly for my front center drive shaft, giving me a wheelbase of around 18". I'll get the front bulkheads together and then be able to fit this in and see where I want to cut the front of the chassis.
Edit: Here's how it looks on the chassis with the battery trays:
brian015
brian015's Avatar
07.02.2011, 01:10 PM
I wanted a solid stand-up servo mount, so I made this out of 3/16" Al angle:
(and thanks to Jeff A (DwightSchrute) for the good deal on the servo for this build!)
Overdriven
Destroyer of Tires
Overdriven's Avatar
07.02.2011, 01:48 PM
Looking sweet Brian. I really like how much you're making on this instead of buying, like the shock towers and servo mount.
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
07.03.2011, 10:23 AM
Glad you like the servo. that's one amazing build. wow! The craftsmanship on your work is awsome, man.
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
brian015
brian015's Avatar
07.03.2011, 11:32 AM
Thanks guys - I guess I'm finding out just how many different parts I can make out of Aluminum angle - seems like just about anything!
brian015
brian015's Avatar
07.04.2011, 07:29 AM
Here's how the front of the chassis looks with the Hyper 9e driveshaft on the front diff - it gives me a wheelbase of 18" - just what I wanted:
So, now I can cut the chassis to length and go from there.
brian015
brian015's Avatar
07.04.2011, 12:43 PM
I was able to cut the front of the chassis today - I left it long because I have an FG bumper that I need to mount on the front, so I'll cut it to its final length when I see how that's going to fit.
I tried to bend the front to give it some kick-up, but this is some tough metal to bend. I have only been able to bend it a little over 1°, so either I'll leave it like that or take it to where I can use a larger vice and bend it more.
mothman
07.04.2011, 12:46 PM
7075 is a very hard aluminium. careful in bending that plate because it might crack.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
07.04.2011, 01:07 PM
Yeah 7075 is pretty hard to bend. Try to make a curve rather than a corner- 1/2" diameter is the smallest curve I'd recommend for material that thick, 3/4" to be safe. Otherwise, like MM said, it might crack.
Edit: Actually I just went back through the thread and saw that it is 4mm thick ( I had thought it was 3mm), so definitely >3/4" diameter to avoid cracking.
brian015
brian015's Avatar
07.04.2011, 04:32 PM
Thanks for the advice, guys - I guess if I decide to bend this more I'll be a little more careful than when I've bent 6061 in the past.
