Metallover
RC-Monster Spudgunner
Metallover's Avatar
05.31.2011, 05:55 PM
Front wheel drive is fine but you can run into traction problems, especially when it's wet out or you have a lot of power. And you can't do wheelies.
Also, mounting is sometimes a slight issue in the front too because the metal the fork is made of is often weaker than in the rear, requiring a stronger torque arm.
