crazyjr
crazyjr's Avatar
06.08.2011, 09:17 PM
HV is good to have as long as the required amount of wattage is met for your setup. However you can only go so far as weight becomes an issue and throws out your gained efficiency.
The cool part is, with all the talk of going up in voltage, I haven't gained weight on the setup. My 4s 3700 flightpower is still lighter than the 6 cell NIMH i used to run
