cmac
cmac's Avatar
08.13.2011, 02:02 PM
OK. I have the hinge pins in when I went to assemble them the Upper (longer) pin sits flush with the arm edges. I can't use the included clips to hold the pin in place. Correct me if I'm wrong but the ends of the pin should stick out far enough to use the c-clips. Did I order the wrong hinge pins? Remember I'm using UE supermaxx A-Arms. By the way I finally ordered the radio that is going to keep this under control.....http://www.rcsuperstore.com/Futaba_4...p/futk4901.htm It should be here on Tuesday or Wednesday.
08.13.2011, 04:10 PM
Which ( brand of ) hingepins did you go with? There do seem to be two different versions for the maxx trucks on a few websites- apparently one version does have slightly longer pins for either the front or rear ( or both ) upper a-arms. You could always cheat though if you dont want to order more pins; drill a little hole in either the bulkhead or a-arm, then put a little setscrew / grubscrew in there which will hold the hingepin in place without the need for e-clips:
http://traxxas.com/forums/showthread...=1#post4404874
Great detailed pics from a fellow RC-M member.
cmac
cmac's Avatar
08.13.2011, 04:14 PM
Neil I bought the fast lane hinge pins. I really don't want to have to drill the arms or the bulks. what are my options?
cmac
cmac's Avatar
08.13.2011, 04:50 PM
Well I just bought two sets of UE titanium hinge pins. I imagine they will work(they better!!!!!).
cmac
cmac's Avatar
08.13.2011, 10:56 PM
If I were to get a 4 pole Neu Castle motor would the ESC that came with my brushless Emaxx work with the new (Neu) motor? Or would I have to get another ESC?
dtnel
08.14.2011, 12:45 AM
The 14500 pins from flm are the ones for the hybrid bulkheads. THe 14500 has 3 different sizes whereas the 14000 only has 2 different size pins in the box. I Have the one with the 3 different size pins but I haven't installed mine either yet......
cmac
cmac's Avatar
08.14.2011, 08:20 AM
I just checked the label on the bag, and it is indeed the 14500. Only two size upper and lower pins, and the uppers are too short.
WEB
08.14.2011, 12:27 AM
It wood work fine with what you have,it going to be a nice truck when you finish it keep up the good work.
cmac
cmac's Avatar
08.14.2011, 07:15 AM
Thanks Web....
cmac
cmac's Avatar
08.14.2011, 07:13 AM
From the the picture the 1400 and the 1450 look the same. I have a set (1450) coming to the house. Between the UE titanium pins and the 1450 pins hopefully one set will work.
dtnel
08.14.2011, 08:57 AM
Thats definitely a oddity. I Have 3 sizes and you 2 from the same part no.
cmac
cmac's Avatar
08.14.2011, 09:37 AM
So there are two different types of upper a-arm pins "long" and "longer"? That would also mean that your bag would have 12 pins in it, right?
dtnel
08.14.2011, 02:54 PM
I have 8 in the bage. Note the 3 different sizes,
FLM 14500 hinge pins. 3 sizes, 8 total pins in the pack
dtnel
08.14.2011, 02:58 PM
I have 8 in the bag. Note the 3 different sizes,
I need to get my Ofna hyper 7 diffs shimmed so I can get them wrapped up but I drag my feet as usual. I did go and buy a box of the RC Screws this past week so this truck will get the silver bolts. Wish I had the money to color my chassis and such a purple or something like that though.
cmac
cmac's Avatar
08.14.2011, 02:59 PM
Thanks, I see. Are you going to use UE arms too? I think there is just more material on the outer parts of the upper A-Arms, and that's why the pins are not long enough. The bottom pins are perfect. I think the UE ti-pins will do the trick, and I will be able to use the Fast lane uppers on my original E-Maxx. Thanks dtnel.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
