ransom
06.20.2011, 04:30 AM
yes it does sound like a bad solder joint or battery connector or the esc is hitting low voltage cuttoff
is it a new install? new esc ?
is it set for the packs you are using?
check settings on the program card
if you dont have a program card for your xerun then you need one
