simplechamp
simplechamp's Avatar
06.20.2011, 08:15 PM
Today I 4-linked the rear end of my SCX10. Used the Axial truss with Delrin links and RC4WD plastic rod ends. I made the links 2mm longer to adjust the pinion angle upward a little bit. Going to 4-link the front in the next few days with the same setup.
I also swapped out the cheapy Blue Bird servo for a Spektrum S6030 (278 oz-in, 0.15 sec). Tested the servo using the Sidewinder internal BEC, but will be installing a Castle 10A external BEC tonight.
