06.22.2011, 12:00 PM
Originally Posted by nuz69 View Post
You are taking the problem from the wrong side.
The point is that HV voltage runs not necessarily cooler... For the motor it's pretty much the same, although the ESC is a little cooler with HV setup. So the gain in efficiency can sometimes be negligible...
Even so, an efficiency difference of even a minuscule 0.5% on a 400w average draw is a difference of 2 watts worth of heat. That doesn't sound like a lot, but take a hold of a 5w resistor dissipating 2w and you can get the idea.
No matter what, ANY heat on the motor, ESC, battery, wires, etc is lost power. All those have a given resistance. Current^2 * Resistance=power.
Higher voltage means less current, so less voltage drop and power loss on those components. This means more of your battery is getting to the ground.
Here's some numbers for ya:
If your system is pulling say 300w average, running that on 2s means 40.5A. That 300w on a 4s setup is only 20.3A. 300w average power is pretty typical for a smaller 4WD vehicle.
So, if you have a total resistance of 0.05 ohms for the motor, esc, and wires, that's a loss of 82W on 2s for a system efficiency of 72.67%. But on 4s, that's a loss of 20.6w for a system efficiency of 93%. Big difference there!
So, I really don't understand the argument and confusion here. It seems pretty simple to me.
nuz69
nuz69's Avatar
06.22.2011, 12:17 PM
In terms of heat, ok, a single watt loss is always too much. But in terms of runtime ? Worth it to add 200$ in order to gain 10 sec on 15 minutes racetime ?
Low Kv brings also smoothness for some people who drive brushless motors like nitro engines (trigger ON-OFF). Due to the higher inductance, a low Kv motor has higher response time, some kind of intrinsic punch control...
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
nuz69
nuz69's Avatar
06.22.2011, 12:30 PM
I am sorry BrianG, your math is false ^^ This would be too easy to gain efficiency you don't think ?
The motor resistance gets higher as the Kv drops (more turns and smaller wires).
For example you need to double the number of turns to get the Kv divide by 2, that means for the same volume of copper (both motors have same weight), the wires section/surface is divided by 2, that means the resistance is multiplied by 4 :
R = resistivity * (lenth/surface)
So the R*IČ loss is exactly the same for the two motor (I multiplied by 2 but R divided by 4). Someone explained this point above. And in reality it's not as simple as that. Sometimes it's easier to package thin copper wires in the can, sometimes not, so the resistance is also affected...
But there is a gain of efficiency in the ESC/Battery wires and connectors, and in the ESC. And this is this little gain you have to calculate, do you have some wires connector resistance values ? ESC is like 0.0003 Ohms...
BIG-block
06.23.2011, 09:20 AM
First of all I am with Brian on this. Any heat is wasted power and lost efficiency. Might not make a big deal in run time but I do think that it has to make some. Is that worth the bigger $$$ outlay of a HV system??? Not for some and for me neither. Why I do like HV is the fact that my ESC runs cooler and has easier life for the same amount of power. This should mean that it should also have a longer life. Batteries too. So there has to be some money saved there to go some of the way of paying for the HV setup. Any of that make sense to anyone or just in my head?
Also I can swear that my motor runs cooler too. I remember my CC 1515 1Y getting rather toasty on 6S but my 1520 geared for some speed runs much cooler. Maybe because the can is bigger and can dissipate more heat????? Either way all of my MT's and Truggies will end up running 8S eventually with the buggies running 6S.
pinkpanda3310
pinkpanda3310's Avatar
06.23.2011, 09:56 AM
Not really a fair comparison with those motors. One is smaller and higher kv the other large and low kv and running the same voltage.
nuz69
nuz69's Avatar
06.23.2011, 09:58 AM
Totally normal, the longer motor has less magnetic losses because it spins at lower RPM and the can is longer so it dissipates more... This is not the compairison we talking about, here it is :
1515/1Y 2200Kv on 4S
1515/2Y 1100Kv on 8S
2 motors of same length and weight. I don't know the neu specs but I am pretty sure that the internal resistance of the 2Y will be ~4*more than the 1Y
You try the both setup, geared for the same speed, you will find ~ same temps for both motor, although the ESC will be cooler.
To keep the runtime equal, you need for example to run 4S 5000mAh and 8S 2500mAh, 2 batteries of same weight and price.
So the battery discharging rate is also divided by 2 ==> the 8S will operate at ~ same temp too.
That's why I said earlier that the efficiency gain in HV setup will be mainly in the wires and the ESC, not necessarily in battery and motor...
Just my 2$
